Subs popping
Noah66
ground loop? try unplugging the inputs to the amp high level and low level? is there a bad ground somewhere or a ground loop to the inputs that could be a problem you might need a ground loop isolator
Also check that the inputs arent "partially" plugged or unplugged that can cause buzzing and popping and bad outputs too..
I’ve seen RCA’s do that stuff before , maybe wiggle or turn them when the systems on to see if it intensifies.
  • Who's Online   1 Member, 0 Anonymous, 725 Guests (See full list)
