tmoney09 Posted April 11, 2019 Report Posted April 11, 2019 So to keep a clean look I built a wooden floor that goes around the box and fits the shape of the trunk. I figured that covering the port like that would effect the sound but not as drastically as it did. I hate to cut a hole in the floor but if that's what it takes to give it room then so be it. But my question is do you guys think if that would really help. In the second picture I drew a line on where I would cut out some of the wood but regardless half of the port would be firing above the wooden floor and the bottom half will be firing under the wood. I want to take out as little as possible but if necessary I will remove more that's shown in the second photo.
Joshdashef Posted April 12, 2019 Report Posted April 12, 2019 Is it possible to sand a slope/angle into the piece in front of the part? Wondering if that would achieve the same results and allow the floor to remain there somewhat SMD Tool Map (2024): https://www.stevemeadedesigns.com/board/topic/226545-smd-tool-map-2024/ Great Box Bracing Examples: https://www.stevemeadedesigns.com/board/topic/202148-best-way-to-brace-a-box/?do=findComment&comment=3055002
Mike4068 Posted April 12, 2019 Report Posted April 12, 2019 Covering the port will lower the box tuning. A good rule of thumb is to have the port unobstructed the same distance as the width of the port.
tmoney09 Posted April 12, 2019 Author Report Posted April 12, 2019 I guess I could actually build a piece that goes all the way down to the floor. I had been working on this box for weeks and I was at a point I just wanted it over with. This enclosure has been a major headache. I've built several boxes and never had this much trouble haha
