gaining db
hopefully i can get some input on this, but i have a 2 dr 08 altima w/ a trunk wall that has 2 skar vxf 15s on a taramps md5000.1 w/ limitless 45. The highest i have been able to pull from it is a 150.96 in the passenger kick (driver door open). Question is, whats some tips on gaining db?? i havent deadened a single thing yet (i know, i know, its coming later this week). (i do have a sunroof) Will birching the roof help?? also, it is completely sealed off from the trunk. Thanks!
Have you spent any time tuning your box? Adjusting port area and port length is a good place to start. Sound deadening is an odd one, can be hit or miss depending on resonances
Not yet. It’s two 6 inch aero ports tuned at 34hz. I thought about buying a flare set to add some length and bring the tuning down a little
Play with window positions, Seat positions,Deadening, Try some different burp freqs too...Spl is an odd creature sometimes the most trivial changes make a difference
Team MaxRetribution
Si Vis Pacem Parabellum
You should also monitor your battery voltage during use. Find out how much current you're pulling and how you can get more current to the amp. Adding a second battery on my setup gave me an extra 275 Watts RMS
  • Who's Online   0 Members, 0 Anonymous, 3338 Guests (See full list)
