Jimmie's 96 GMC2500 - Epic 1st "BUILD"
Great start bud. Welcome to the forum. I'm down in the golden triangle around Beaumont so not too far from you.
  4 FI X 10
 270 CES alt
D3400/73ah lithium
 AA 3800.1
  (2) AA 75.4
On 6/20/2019 at 9:18 PM, Ron36 said:
I’ve learned over the years when it’s your own stuff go slow no rush and it always comes out better. Great start looks good.
Thx man. I agree, gta love the process n take pride in your work. But, if I had nothing else to do, I'd probably spend way too much time on this stuff lol
Thanks. Yea you're only an hour n half from me. Always good to meet a fellow Texan who loves his music
  • 3 weeks later...
A bit of progress to date:
20190621_002245
First layer of Fiberglass and checking the overall layout and flow of the door panel.
20190705_184119
Getting it roughed in n almost ready for the duraglass.
20190712_162443
 I decided since I'm already working on this, to go on n mold the seams, fill in the door light hole and remove some of the vents in the bottom of door... I'm going to mount some blue LED's behind the 3 remaining slots to come on when door is opened.
20190712_161802
Got it pretty close to how I want it, just cleaning up the edges and need to trim the foam inside the speaker holes a bit... And I believe I may be ready for a coat of Rage. Getting closer.
Nice work brother.
Are you planning to open up the door to match or are they going to fit leaving the doors stock ???
Not sure if I know what you mean by "open up the door"?
...But (aside from the trim panel above armrest and one that I'm making to balance out the middle of door) they will be painted black w silver pearl to match the outside whenever I get the rest of truck ready for paint. And I'm thinking of a 1" charcoal grey (possibly marbled w silver) stripe following the upper body line that I will continue into door jams and onto the door panel when you open it up.
23 minutes ago, Epic said:
Or are you asking if I need to cut the door for speaker clearance?
Was there a stock 6.5” driver location
Yea there was one, but I couldn't cut a hole for the second speaker because of the window assembly, so I decided to add a raised baffle so the magnets could clear the inner door instead.
I considered only using one set in the factory location and use the kick if I needed more, but somehow I convinced myself that redesigning my door panel was the better option lol ...but also I felt like both mounted side by side would look better and fit the plans i have for the truck, so why not.
Please make sure that your baffles are secure to the doors directly and not depend on the door panel itself. It is rattles waiting to happen. Just ask me how I know ... lol
