I have a 2005 Toyota Matrix XR.....i wanna be a ground pounder. But how? I wanna be able to keep the back seats if i can. I want a BANGIN system. I have about 2000 to spend on stuff. I will already have a 300 amp Irraqi alt w/ big 3 and a 1400 kinetik. Help me out please!!! If I have to i might be able to go a little more on price....thanks
**New setup in the works** Shocker sigs ftw!
*Breakin Glass and Kickin Ass*
Team SBC
Team Full Force
Refs
SMD-derrick, Bangin Explorer, Exposport, Bass 14
CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14
cac.org-Spl Guru, Andrew, dblover, lunari
Basically with the seats all the way back im working with the dimensions 40 wide x 20 deep w 20 tall. So what do you think I can do with that? I was also thinkin bout maybe makin it so if i go to comps i can set down back seats and add subs. Let me know I appreciate any help.
Team SBC
Team Full Force
Refs
With those specs 40x20x20 I calculated about 7.6 cuft before sub and port displacement using 3/4 inch wood. With that space I'd say 2 fifteens should be good. As far as equipment its going to be personal preference. For me with that budget that space and that alternator I would do the following.
Amp: Sundown SAZ-3000d $700 http://www.db-r.com/sell/store/index.php?productID=146
Subs: DC Level 4 fifteens $400 http://www.stevemeadedesigns.com/board/ind...showtopic=20834
Wire: Stinger $108 http://www.darvex.com/miva/merchant.mvc?Sc...Product_Count=1
Wood: 3/4 inch mdf or birch ply around $30 to $40 at lowes or home depot
Speaker wire: Knu 10 gauge $16 for 20ft http://www.knukonceptz.com/productDetail.cfm?prodID=KLE10BL
RCAs: Knu Karma $15 for 6 meter http://www.knukonceptz.com/productDetail.c...rodID=KARSS2.6M
Remote wire: 14 or 16 gauge wire from walmart $8 for 50ft spool I think
Starting Battery: IDK size but assume around $250
Battery: d3100 $300 http://store.summitracing.com/partdetail.a...mp;autoview=sku
Total: $1837 Leaves room for shipping on batteries
Thats just what I'd do in your situation giving the space and budget
Rebuild coming soon
id do one lvl5 18 or an fi btl fully loaded 18 n throw more power at it... just my opinion though.
nah. you dont wanna put very much more power on those (even if you've seen people do it...there's more that goes on behind the scenes that allow that). so in this case...the same power (3000 ish watts from that example) on the pair of subs would better suit him. it'd be louder because of the higher cone area. the extra power you put on an 18" wouldnt make much of a difference imo
i just wanna clarify somethin wit you... as a groundpounder that in my opinion is suppose to be cone area... like wat assman is doin... alot of 10's or 12's... when ur just runnin 2 15's or 1 18 then thats just gettin into spl setups... so which one do you want
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
thats funny. ive never competed, and yet i had 1 18. a groundpounder is someone that just beats down the block no matter what they have.
and assman is competing with all them subs, so you kind of contradicted yourself there.
I know groundpounders usually have a lot of cone area. But its my daily driver that I still want to be able to take to comps and actually compete. With those level 4s in my car does anybody have an idea of what I could be expecting to hit db wise? Also those im assuming in a ported box tuned to what frequency?
Team SBC
Team Full Force
Refs
Check ur pm's
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
