Amp Problems
Just got my Rockford P550.2 amplifier and its giving me problems :S....wen i increase the volume on the deck the amp cuts out. The power light stays on the protection light doesnt come on neither dis the thermal light. Can someone explain to me why this is happening??? :unsure:
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Pioneer AVH-P4900DVD
Clarion EQS746
AudioControl EPIC160
Kinetik HC2400
bad ground, upgrade your power and ground to 4 gauge if it isnt already. and where is your ground located at
and the gain and/or bass boost might be up too high
Edited by Krannyman92
I have to runs of 0guage positive and negative. ground comes straight from the Battery and the gain is on half and i use the amp for Mids not bass
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
Have you tried a different amp?
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
Well I also have a ROckford T20001BD in the jeep and that does not cut out
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
check the speakers that are on the amp, one bad coil could mess it up, and like others said, double check the grounds, power and remote at the amp as well as verify the power at the amp (make sure its 12+volts) with a multi meeter
to trouble shoot you have to check off each thing even if you *know* its rite,... the littlest thing can mess it up
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
Well its not the speakers cause i also tried other speakers, my grounds are good i checked them already, the only thing i did check was the remote i'll check it now and get back to yall .... i'll also try the amp in another vehicle
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
did you say the ground on your amp is going the battery????
you gotta ground it onto the body/frame of the car.
The amp only supports up to 4 gauge power/ground, so make sure its 4 gauge and not 8.
It's fine grounded to the battery....
NVX LOC
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
all my wiring is fine. I tried the amp in another vehicle n its doing the same thing. It still cuts out wen volume is increase :S
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
  • Who's Online   1 Member, 0 Anonymous, 1980 Guests (See full list)
