testing higher (spl) tuning
Hello, one question.. i have 2 sa 12s with great sound quality at 35 hz tuning, 40cm x 7,5 cm slot port in the middle and 5 cubes total net volume.. car peaks at 60 hz..  box at 38... my score is highest at 60hz.. if i model the enclosure in winisd, i need a tuning of 57 hz to be able to get 8dB gain at 60 hz.. in theory... so.. is it possible (just for testing purposes and fun).. to put something in the box to lower the volume for half.. and so raise my tuning and test if numbers really go up at 60 hz? if possible.. what should i put in the box.. bricks of wood? blankets? anything else? if this is even possible.. i am sure its not legit experimenting, but just to see if numbers really go up :) thanks, and don't laugh :p
Yh it would work. But you wanna know exactly how much space each object takes up so you can write down your results.
so work out how much space each item takes up. Do an spl test then check score.
Rinse and repeat.
if you use bottles filled with water it makes finding out displacement easier.
While reducing the internal volume of your box will raise your tuning, its also going to decrease your output at tuning, so its unlikely you are really going to gain anything.
If you want to try a higher tuning frequency to see if you can get a bigger peak SPL number, you are probably going to have to build another box with a shorter port.  Keep in the mind the higher you tune the more port area you need as well or you will get significant port noise and port compression.
Builds:
6 hours ago, Joshy 94 said:
Does it decrease output because smaller boxes are less efficient ?
Yeah, smaller boxes are less efficient around the tuning frequency.  As you move away from the tuning frequency the size of the box has less impact on output, but for what you want to do, it all about how big the box is and where its tuned to.
Builds:
Higher you tune up, the less musical you get.
You will take a BIG chance of damaging your drivers ...
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
