they dont have rotors that are both in one?
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
both in one is the best. cross drilled, and sloted.
Team Deadly Hertz
1997 GMC 1500
Update....
System is gone
Motor is fucked
Truck is down and out for a while
Myspace
YOUTUBE
My Build
which are better for suvs with a 26'' wheel? brembo offers both slotted and cross drilled?
I have baer cross drilled and slotted rotors on my sts with 20s.
Ive heard that the drilling of rotors makes them a little weaker. but its not like youll be racing a suv with 26s so that shouldnt be a problem.
Id say go crossdrilled and slotted if possible for the best cooling, but otherwise if you cant get both in one rotor, go with slotted.
ive been looking for a set of cross drilled and sloted for my truck and i cant fine any. at least not for the year truck i have. 97 full size GMC 2 wd
Team Deadly Hertz
1997 GMC 1500
Update....
System is gone
Motor is fucked
Myspace
YOUTUBE
My Build
DO NOT GET CROSS DRILL ROTORS. Every drilled rotor I have ever seen has cracked. Thats why companies have started dimpling the rotors instead. Cross driiled rotor are not for cooling, they are to vent the brake dust. the slotted vent the dust just fine. the veins in the middle are for cooling. Read the fine print before you buy.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Thanks... I was pretty sure that the cross drilling of the rotors was what made them weaker, but could not remember correctly. :(
There is also a simple soulition to get rid of brake dust too that I found. Ceramic pads FTW :)
I think it was about 2 years ago when I just started to get fed up with having to was my car everyday do to brake dust on my blingage and thats when I went out and bought my baer rotors and ceramic pads. I use to have to change out front brake pads every couple months because they wore so thing, and since I put the rotors and ceramic pads on, I havent messed with it yet :)
i went with Hawk LTS pads and what a difference on the brake dust
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
