single 6.5 sub for mid-bass?
Casparado
originally they came with inline capacitors that high passed at 10k. Now they are on 2nd order (12db slope) L/R @ 5k
I wish I could change the aiming of the mids. They're stuck in the stock door location. The tweets are in the A-pillar
The whole reason I changed the crossover point was because I felt there was some beaming happening from the mids being full range (and in a shitty location)
But back to the original question... since the 5 1/4" mids just aren't designed to play below 100hz at all (according to the Focal technician), and I'm asking them to do so much work already.... wouldn't it make sense to send the mid bass frequencies to a new driver?
3 minutes ago, ToNasty said:
They beam the higher they play.  So you crossing them that high is making them beam faster
Sorry but I'm not following. I thought taking them from full range down to only 5k and below would reduce beaming.
Let me be clear. 1" Tweets in A-pillars are playing 5k-20k. 5 1/4" Mids in doors are playing 100-5k. 12" Sub is playing 20-100hz.  The mid bass region is lacking since I went from sealed to ported. That's what I'm trying to fix.
Originally (from the factory when I bought them) the tweets were playing 10k-20k, and the mids were full range.
Sorry just trying to make sure there's no confusion.
Sub bass drivers are designed completely different from mid bass drivers in most cases. If you want a mid bass upgrade, buy a pair of mid drivers.
installing a mid bass driver in the center console will not work in just about any car audio application. Reason is car audio depends on left and right channel separation just like the mid range and high range. On every head unit made, the only mono channel used today is a dedicated center channel or sub bass. And no, you can not substitute center channel for your mid bass application in question.
Knowing more about your vehicle can help us help you with your application. This a single cab or an extended cab ??? My personal suggestion on this would be to upgrade the 5.25" drivers to 6.5" drivers (Modification behind the door panels of course) and retune.
It's a 2 door extended cab. I removed the rear "seats" (tiny little fold down things), and filled the area with a 29x14x17(ish) subwoofer box and an amp rack.
Modifying the door panels is what I'm trying to stay away from. It would be easy for me to build a center console box from scratch, and I could fit two 6.5" speakers in there (But at least one would have to face upwards) in order to get around the stereo signal issue. (Thanks for reminding me about that.... that would have sucked losing a whole channel of sound.)
At what frequency can our ears detect stereo separation? I know it's not a stead fast frequency but a slope, but if I have them only playing from 70-150... will it be that obvious that they're in the center playing upwards instead of in the doors playing on either side? IOW, if I cross them over at 150 instead of 250, will it be less obvious that they're not on the left/right sides of the vehicle?
And thank you for your help guys, I really do appreciate it, and I am willing to think outside of the box and hear all ideas. If I gotta modify the doors then that's it... I would just prefer not to. But I'm open to all ideas.
  • Who's Online   0 Members, 0 Anonymous, 1089 Guests (See full list)
