thegr8cody Posted May 7, 2008 Report Share Posted May 7, 2008 well my blazer runs around the 2nd line before 210 no matter how long i drive it.and i noticed my buddys yukon chills around like 160 so i dont know what it is im thinking when i replaced my thermostat i put a 180 in it instead of a 160? anybody ever had this problem?brand new clutch fan filled up with coolant not sure what else there is Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
Stephen Posted May 7, 2008 Report Share Posted May 7, 2008 well my blazer runs around the 2nd line before 210 no matter how long i drive it.and i noticed my buddys yukon chills around like 160 so i dont know what it is im thinking when i replaced my thermostat i put a 180 in it instead of a 160? anybody ever had this problem?brand new clutch fan filled up with coolant not sure what else there is what year and motor is the blazer? Quote you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER Link to comment Share on other sites More sharing options...
thegr8cody Posted May 7, 2008 Author Report Share Posted May 7, 2008 98 4.3 not sure what model the motor is i think its like x or something Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
may03LT Posted May 8, 2008 Report Share Posted May 8, 2008 I would consider 2 lines under halfway normal for a gm......now erratic gauge/ overheating/ fluid loss.....that would be a problem Quote Link to comment Share on other sites More sharing options...
mrwigglezdj Posted May 8, 2008 Report Share Posted May 8, 2008 yea thats nothing to worry about, ofcourse the temp will be higher on the gague since you put in the 180 from a 160, but 210 isnt a temp to be in a worry about, if you feel unconftrable with the current temp, just replace it with the orignal seting thermo Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets Link to comment Share on other sites More sharing options...
thegr8cody Posted May 8, 2008 Author Report Share Posted May 8, 2008 ok thanks guys Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
dwright27 Posted May 8, 2008 Report Share Posted May 8, 2008 my silverado has ran 260, and dumped coolant/water through the exhaust pipe. and the head gasket is blown, so if you get that, its the head gasket going 9 times out of 10. Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
badasschevy Posted May 8, 2008 Report Share Posted May 8, 2008 my silverado has ran 260, and dumped coolant/water through the exhaust pipe.and the head gasket is blown, so if you get that, its the head gasket going 9 times out of 10. are you sure its the head gasket? the 96-98 5.7 vortecs are notorious for the intake gaskets going to shit. they will also cause coolant to leak into the oil, and out your exhaust. Quote center console: lvl 4 12 1.75 cu ft tuned 37htz alpine cda-9886 dc audio 120.4 infinity kappa 6.5" components Link to comment Share on other sites More sharing options...
dwright27 Posted May 8, 2008 Report Share Posted May 8, 2008 are you sure its the head gasket? the 96-98 5.7 vortecs are notorious for the intake gaskets going to shit.they will also cause coolant to leak into the oil, and out your exhaust. its the 4.3 vortec. and theres oil in the coolant. Quote 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer Link to comment Share on other sites More sharing options...
thegr8cody Posted May 8, 2008 Author Report Share Posted May 8, 2008 mine got around 240 and spilled coolant after trying to make it home when my thermostat when out thats about it but its about 190 - 200 all day long idling 80 -90 degrees outside Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0 Link to comment Share on other sites More sharing options...
