well so far plan is 0 guage wiring throughout, 300 amp ohio generator alt,2 powermaster d3100 in the back and a powermaster d2400 under the hood and this will be pushing a 3000 watt sundown amp and one of there 4 channel amps..
Nice. But I mean what ohm load.
You can never go wrong with buying better equipment. I vote for one BTL.
uh the 3 subs will walk all over the single sub in optimal installs :rolleyes: :rolleyes:
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
763 Sq/In > 255 Sq/In
couldn't of said it better than myself
i don't understand why anybody would try to convince him to get one 18" btl over three 18" Q's, in a proper box wit good clean power (which he is in the right direction) the three 18" will shit over one 18
Edited by KWP369
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
