BassMunky Posted January 23, 2020 Author Report Posted January 23, 2020 53 minutes ago, SnowDrifter said: If it will help is dependent on if that's the problem. Give the drivers it's powering an inspection too. Make sure a tinsel didn't pop off or cross somewhere Mids? That will cause a fuse to blow on the amp? Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
SnowDrifter Posted January 23, 2020 Report Posted January 23, 2020 35 minutes ago, BassMunky said: Mids? That will cause a fuse to blow on the amp? What do you suppose happens if you have an amp powering a driver with a short that has a 0 ohm resistance? 1 Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
deathcards Posted January 23, 2020 Report Posted January 23, 2020 (edited) https://www.youtube.com/watch?v=DJOX0c60wQE 3:47 Edited January 23, 2020 by deathcards 2 Quote skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
BassMunky Posted January 23, 2020 Author Report Posted January 23, 2020 7 hours ago, SnowDrifter said: What do you suppose happens if you have an amp powering a driver with a short that has a 0 ohm resistance? 7 hours ago, SnowDrifter said: What do you suppose happens if you have an amp powering a driver with a short that has a 0 ohm resistance? Yeahhh... I just never heard of it happening. Also tweeter too? Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 23, 2020 Author Report Posted January 23, 2020 2 hours ago, deathcards said: https://www.youtube.com/watch?v=DJOX0c60wQE 3:47 Wowe Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 24, 2020 Author Report Posted January 24, 2020 bumpp soo a loose ground could have cause it? why would the amp still work if only 1 fuse was still inserted an the other 2 was taken out? Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 24, 2020 Author Report Posted January 24, 2020 15 hours ago, deathcards said: https://www.youtube.com/watch?v=DJOX0c60wQE 3:47 Huh? Why change vid try put the orig back thanks Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted January 25, 2020 Author Report Posted January 25, 2020 Buuump Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
deathcards Posted January 25, 2020 Report Posted January 25, 2020 (edited) all i did was add a time stamp? but on a serious note you could have a defective coil which slowly died versus say something as catastrophic as the wrench melting in seconds. tinsel lead could have come in contact with something it shouldn't. As for your fuse question it is wired in parallel (correct if i am wrong here folks) so your fuses blew in order of weakest to strongest in an attempt to protect your amp and by the 3 fuse it was making a racket as you could tell. I would check ground first remember to disconnect the rca's before you disconnect the ground, i would check the resistance of your speakers, then inspect your wires, and finally try a different input source. edit spelling Edited January 25, 2020 by deathcards 1 Quote skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
BassMunky Posted January 25, 2020 Author Report Posted January 25, 2020 4 hours ago, deathcards said: all i did was add a time stamp? but on a serious note you could have a defective coil which slowly died versus say something as catastrophic as the wrench melting in seconds. tinsel lead could have come in contact with something it shouldn't. As for your fuse question it is wired in parallel (correct if i am wrong here folks) so your fuses blew in order of weakest to strongest in an attempt to protect your amp and by the 3 fuse it was making a racket as you could tell. I would check ground first remember to disconnect the rca's before you disconnect the ground, i would check the resistance of your speakers, then inspect your wires, and finally try a different input source. edit spelling Ok gonna try tomorrow. Mahalo Quote Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
