Goldenbigboy Posted January 24, 2020 Report Posted January 24, 2020 I currently have 4 audiopipe txxbd12 s. With a 3000 watt amp. Would I get a great difference if I switched to 2 15 inch sundown zv5s with a 4000 watt sundown amp in a custom box? Like a $4500 difference? I'm looking for mind blowing window shattering bass.
ehall8702 Posted January 24, 2020 Report Posted January 24, 2020 I personally wouldn't spend an extra 4500, u have more cone area right now, and IMHO I don't think there would be any gain with the Sundowns. If it were me I'd spend my cash either in a better box /amp combo or adding more if the current subs you have cause u know what's better than 4 12"s? 6 or 8 12s lmao.4 12s in proper box with good power on good electrical should absolutely numb your eyes. My 4 8s would make u go cross eyed after 20-30 minutes if straight pounding. I'm sure 4 12s would be alot more obscene, I'm working on a setup for my new 15s ( 3 of em) and hope it's gonna be retarded. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz
