Stoneylowe Posted February 4, 2020 Report Posted February 4, 2020 Hey guys, my systems have always been pretty simplistic with passively crossed components but on this next build i want to get more technical and throw in a DSP with a crossover network. The only problem being that i barely understand them for the life of me. Take for example my upcoming build, i plan to have 2 6.5s and a tweeter in each door along with my sub. Does that mean i need 7 separate channels of amplification and processing? It seems like all the DSPs are 6 channel, and i only planned to run a 4 channel and a mono block like i always have, so i feel like there’s something I’m missing. Hopefully someone can explain it a little better, dont go too hard on me i know I’m a dummy lmao. Thanks y’all.
dolarbilz Posted February 4, 2020 Report Posted February 4, 2020 Dayton audio has a basic dsp with 8 outputs.. perfect for starting point. Since you'll be using two 6.5 per door you could just wire the 6.5 together on rear out put on amp.use front out put for tweeters.
Stoneylowe Posted February 4, 2020 Author Report Posted February 4, 2020 Good call on wiring the fronts together didn’t think about that, I’ll put some thought into it, that might work. And i wasn’t even aware of that Dayton dsp, that might be game changing thanks for the heads up
AaronT Posted February 4, 2020 Report Posted February 4, 2020 You can also feed a separate 4 channel for mids off rear RCA and likewise on another seperate 4 channel for tweets using front RCA. Many options , in my suggestion you'd be using 9 channels of amplification with 5 channel's inputs (front, rear, sub signal and 3 amps)
