HELP
Loslegend
I have 2 doc 4 ohm subwoofers,they are wired in parallel to 1 ohm on a 2400.1d quantum audio extreme mono block(not really that much wattage)the wire is not ran into the other sub they are connected at the terminal cup,but the problem is my subwoofer furthest away from the terminal cup is moving less than the other one wich I know affects spl,I check all voice coils they still read one ohm and they are all still wired up correctly,any ideas???
  • 4 months later...
Are you 100% sure on the wiring?
What woofers and how is your box?
Some woofers handle uneven loading in the box quite poorly, others seem to overcome it really well. So if your box in unsymetrical that might be a reason.
  • Who's Online   0 Members, 0 Anonymous, 1609 Guests (See full list)
