Forceww Posted May 9, 2008 Report Share Posted May 9, 2008 I am thinking about the sundown saz-3000d to run two level 4 DCs and was wondering what everybody thought of the amp....ALSO I heard this thing can do a number on your electrical if its not up to par so what does everyone recommend as far as electrical upgrades for this BEAST???? Thanks **New setup in the works** Shocker sigs ftw! *Breakin Glass and Kickin Ass* Team SBC Team Full Force Refs SMD-derrick, Bangin Explorer, Exposport, Bass 14 CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14 cac.org-Spl Guru, Andrew, dblover, lunari Link to comment Share on other sites More sharing options...
banginAltima Posted May 9, 2008 Report Share Posted May 9, 2008 The Sundown 3000 is an awesome amp. You will need atleast two batteries and a high out put alt if you run at .5 ohms. If you run it at 1 ohm you might get away with one battery and a good alt. If you run at .5 ohms without a good electrical, you will burn it up! If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs Link to comment Share on other sites More sharing options...
Forceww Posted May 9, 2008 Author Report Share Posted May 9, 2008 What size alt and batts do you recommend? **New setup in the works** Shocker sigs ftw! *Breakin Glass and Kickin Ass* Team SBC Team Full Force Refs SMD-derrick, Bangin Explorer, Exposport, Bass 14 CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14 cac.org-Spl Guru, Andrew, dblover, lunari Link to comment Share on other sites More sharing options...
banginAltima Posted May 9, 2008 Report Share Posted May 9, 2008 I think you should send sundownz a pm for the exact size of batts and alt. you need. Cause I would tell you to get the biggest battery(s) that you can get but you might only need a midsize battery. Its not going to hurt if you do an over kill on your electrical. You could spend the money to get two really good batteries and not have to get a alt. but know this... batteries only store the power so you could bang it hard for one to two songs but turn it down to charge the batteries back up. If your the type of person to bang the music all the time then you need atleast a 200 amp alt. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs Link to comment Share on other sites More sharing options...
Derrick824 Posted May 9, 2008 Report Share Posted May 9, 2008 www.sundownaudio.com Click on products, click on saz-3000d, then scroll all the way to the bottom of the page. Link to comment Share on other sites More sharing options...
Forceww Posted May 9, 2008 Author Report Share Posted May 9, 2008 THANKS!!! I think im going to run a powermaster 3100 and probably at least a 220 amp Irraqi alt **New setup in the works** Shocker sigs ftw! *Breakin Glass and Kickin Ass* Team SBC Team Full Force Refs SMD-derrick, Bangin Explorer, Exposport, Bass 14 CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14 cac.org-Spl Guru, Andrew, dblover, lunari Link to comment Share on other sites More sharing options...
A&W ROOTBEER Posted May 9, 2008 Report Share Posted May 9, 2008 THANKS!!! I think im going to run a powermaster 3100 and probably at least a 220 amp Irraqi altim using that same amp along with there 4 channel amp and im using 2 powermaster d3100 model batteries in the back with a d2400 model under the hood and a 300 amp alt.. Link to comment Share on other sites More sharing options...
Rose-Villian Posted May 9, 2008 Report Share Posted May 9, 2008 Im running 4 SAZ3000D's @ .7 Each... On 3 300Amp Alts and 5 HC2400's.. And My Voltage Is fine... Im adding 4 more HC2400's To help keep my Number's Steady... But GREAT AMPS...I Couldnt Ask for More! Jacob Runs a Great Company and Has the BEST CS ANYWHERE....PERIOD! WWW.OSGINDUSTRIES.COM I LOVE HATER'S Link to comment Share on other sites More sharing options...
sundownz Posted May 9, 2008 Report Share Posted May 9, 2008 Thanks for the props -- Your 220 amp alt and Powermaster D3100 will do nicely! If you can, run the amp at 1 ohm - it is a good bit more efficient than @ 1/2 ohm and the power difference is not audible dropping to 1/2 ohm. Operation below 1 ohm should be reserved for SPL competition where a few tenths matters. - Jacob Fuller - Owner, Sundown Audio - Sundown Audio on FACEBOOK - Please DO NOT PM ME -- use my email address -- [email protected] Link to comment Share on other sites More sharing options...
BigPimpin91 Posted May 9, 2008 Report Share Posted May 9, 2008 Thanks for the props -- Your 220 amp alt and Powermaster D3100 will do nicely! If you can, run the amp at 1 ohm - it is a good bit more efficient than @ 1/2 ohm and the power difference is not audible dropping to 1/2 ohm. Operation below 1 ohm should be reserved for SPL competition where a few tenths matters. Quick question.It's not listed on the site, but what is recommended for the 1500D? BigPimpin91's Banging Music Link to comment Share on other sites More sharing options...
