All Night Long Posted May 9, 2008 Report Share Posted May 9, 2008 The powermaster d3100 will be more than enough for the 3000d, and a high amp alt isn't extremely necessary. There are a few guys here in Ohio running the 3000's on stock alts and they are putting out some serious power just fine. The battery is what is going to help out the most. I had two hifonics thor's running off of two kinetik 2400's and a stock alt in a chevy blazer and they draw way more current than a single sundown 3000d. The alt will help the situation if you don't ever plan on putting your batts on a battery charger, but if you are not beating down the system all day everyday a strong batt upgrade will be sufficient. Unless you have the extra $300-400 to spend then go for a high output and it will help to keep the voltage regulated and also get rid of that annoying light dim. Link to comment Share on other sites More sharing options...
Forceww Posted May 9, 2008 Author Report Share Posted May 9, 2008 Ok thanks everybody!!!! **New setup in the works** Shocker sigs ftw! *Breakin Glass and Kickin Ass* Team SBC Team Full Force Refs SMD-derrick, Bangin Explorer, Exposport, Bass 14 CA-connersdad19 x2, Ridnclean, Deafdreamz, nismos14 cac.org-Spl Guru, Andrew, dblover, lunari Link to comment Share on other sites More sharing options...
Torres Posted May 10, 2008 Report Share Posted May 10, 2008 i didnt have half the power i have now from my old setup, and my stock alt eventually died from it. and i was in a not so good part of town. just somethin i wouldnt wanna cut corners on... Link to comment Share on other sites More sharing options...
sundownz Posted May 11, 2008 Report Share Posted May 11, 2008 Quick question. It's not listed on the site, but what is recommended for the 1500D? Most stock systems with a healthy battery, an alternator of 100+ amps, and the big 3 are fine for the 1500D @ 1 ohm. - Jacob Fuller - Owner, Sundown Audio - Sundown Audio on FACEBOOK - Please DO NOT PM ME -- use my email address -- [email protected] Link to comment Share on other sites More sharing options...
