15" zvx starts to smell close to 3/4 volume
TheMusicBox
9 minutes ago, TheMusicBox said:
I just re wired all connections and upgraded wires voltage drop was about 13.4v from 14.5
nice, glad ya did that then
15" Neo Elite
135AH Lithium Bank
Taramps Bass30k
320a Brand X Purple Metallic Ho Alt
125+ Ft of oversized 1/0
I'm assuming when you set the amp at 44 volts which is just a tad under 2,000 Watts that you had the DECA set to all flat?
now if you played with any settings on the deck after you said everything up like that is some EQ or anything like that you're definitely going to change the input voltage going to the amplifier and it's not going to be putting out 44 volts in the morning it's going to be putting out more, which is going to put you into the clipping area
  • Who's Online   1 Member, 0 Anonymous, 1503 Guests (See full list)
