TheMusicBox Posted February 27, 2020 Author Report Posted February 27, 2020 The HU is a stock unit Harmon kardon And I did adjust the line out converters. I did use a 40hz tone I was just making sure this is the way to do it.
TheMusicBox Posted February 27, 2020 Author Report Posted February 27, 2020 All EQ settings are flat 100% I use focal component 6.5s in the front and rear on crossovers
AaronT Posted February 27, 2020 Report Posted February 27, 2020 It may be just the music you're listening to higher decibel level Might be getting a little bit of clippy or just some new sub smell from running the thing at its Max
TheMusicBox Posted February 27, 2020 Author Report Posted February 27, 2020 I was also thinking that aswell it has about 4-6 hrs of play time.
TheMusicBox Posted February 27, 2020 Author Report Posted February 27, 2020 Well after all the input from you guys the problem has been resolved. I cleaned up all wires,connections and re-tuned the subwoofer amplifier @38v and I can now play all the way up to my clean volume level with no distortion or smells. Also the system as a whole feels alot more powerful and very clean. Btw the voltage drop is only @ .5v now after re doing all power wires and connections. I would like to thank all who helped me on this issue . I really appreciate it.
AaronT Posted February 27, 2020 Report Posted February 27, 2020 Your voltage drop was more than likely from decent clip.
TheMusicBox Posted February 27, 2020 Author Report Posted February 27, 2020 My mid bass improved also. Crazy I thought I wired everything well the first time. I actually used my new crimper and heat shrink and helps. Never going cheap again on another build.
TheMusicBox Posted February 27, 2020 Author Report Posted February 27, 2020 I most likely will upgrade the amplifier, it's a good amp but it's a budget subwoofer amplifier for sure.
MichiganBumps Posted February 27, 2020 Report Posted February 27, 2020 13 hours ago, TheMusicBox said: I most likely will upgrade the amplifier, it's a good amp but it's a budget subwoofer amplifier for sure. personally since u have a system going id look into a alternator. 15" Neo Elite 135AH Lithium Bank Taramps Bass30k 320a Brand X Purple Metallic Ho Alt 125+ Ft of oversized 1/0
