Got tired of using the cardboard for these tools so I bought a pelican case (V100 vault series). It has enough room for two smd tools, probes, and some accessories.
Ran out of time to finish it tonight but will add photos as I complete this project. I think I'll end up using some blue felt on the underside to show when I pull a tool out but who knows.
spacer.pngaeb4ff5888bf9f5d0844c41c9e7b3894e4271fb9
03a058b7f8c226147b6af643049e16108d120542spacer.pngea73c4fb9816d9af6b1cb54db8a6373aa2e1b06e
672480a7ddc7e8b7ed1f9645ad1934102bacdb3da47d06ebbc84cffde4c4daaa16061b64d3e3ab2e3f0c04828ca9451afd33072d92538aabce2f88e3
I had a much easier time with the second cutout compared to the first! I found that the long straighter cuts are much smoother if you go about half way through the foam on your first path then close to all the way through on your second pass with the blade. Also if you cut with the blade coming directly at you, with your eyes level with the foam (gonna have to bend those knees), you can control the blade far better than looking down on it.
Finished up the rest of the foam cutting this morning. Plan on adding some felt underneath to show when you pull a tool out, likely a light blue.
Cut out some of the foam on the bottom to allow the wires of the probes to sit easier. Lots of trial and error to get it to fit properly.
55625b8ef6c406b1138af46b40bdefd66b95d823
0b352b85c10d5b8ceca04b74d2f669d630adb4ec4187bb1a4f79ed9609e12e688f4a5fcfe540be7f
Put the cd's under all the tools in case I need them, but I mostly use bluetooth or usb files to tune anyways. Manuals are tucked under the top foam also. Each side has its own probe with some velcro to hold them together.
285768be10d2322e6b5fda3535b8ede414ac8dea7ca0df59e56ff1af48e2011ed36e5b261894b38f
