Math check on center slot port enclosure for 2 SA 12's
Good evening everyone,
I am looking for a quick math check on a box design and confirm my center slot port length
Overall enclosure dimensions:
W - 30.25"
H - 14.25"
D - 25
Material - .75"
Woofer displacement .28
2 common port walls
Port W - 4"
Port H  - 12.75"
Port Length 19"
Does that port length of 19" look correct to come out with a tuning freq around 34.97, 51.00In2 Port area, 4.99 ft3 gross and 4.19ft3 net?
And on sundown subwoofers I would run the enclosure and port area 10-20% larger than recommended depending on the amp. The weaker the amp, the weaker the enclosure the smaller the increase and vise versa. If you’re running them subwoofers at rated or close to the I would make the enclosure 20% larger than recommended, volume and port area for better sound. And I would tune it a little bit lower to compensate for the increase. And if you’re running around double rated, like most people do, then I would run the enclosure around 10-15% larger in volume and port area and tune it a little lower than recommended.
:guido:
4 hours ago, lilrezy50 said:
Thank you guys, I’m running a KX 1600.1 @ 2
Seems to be within minimum port area requirements to avoid loss of output due to velocity but it could be bigger if you have the room to fit a larger port. 60-70” would be closer to ideal
Agreed. 60” would be ideal. That’s a 15% increase. 70” is 34% bigger than recommended. That might be a little too much of an increase. Under the right circumstances and remaining figures he could make that work. But like you said 60” would be super ideal. That 15% percentage of increase is my go to and what I design most of my enclosures to. But with 60sq” of port area he would need to increase the net volume of his enclosure the same percentage and then lower the frequency to about 33hz. But if he changes the port area to 60” and extends the length of the port to lower the tuning it would bring his original enclosures net volume down about 5% and since it was already 19% larger than recommended he would be right on the money and ready to go. He could leave it at 35hz and be fine but since the enclosure has been altered from recommendations for better output then the frequency has to be changed as well for better output to meet the new expectations the subwoofer would want to achieve the new higher output capabilities.
:guido:
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
