Final Impedance 2 x 8ohm + 4Ohm Tweeter
Dragonware
Will I blow up my amp or just be running under powered
Taramp DS800x4  2ohm
Amp is capable of running 400RMS x 2 @ 4ohm in bridge mode.
Would like to run in parallel
1 Eminence 8 inch beta  -225 RMS @ 8ohm
1 Eminence 6.5 Beta -175 RMS @ 8ohm
without adding a second amp just for the tweeters can I add my 4ohm Soundstream SST-05 Bullet Tweeters they are 50 RMS @4ohm
What will my final impedance be and how will the power distribution to each speaker be ?
if this will drop the impedance below 4ohms i would prob stay away from this dont want to stress the amp
If I had to add a dedicated tweeter amp the Taramp DS250X2 would be my choice for this application.
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
can no one help ?
My Build log :
Current System
Audio Control LC7i
Taramp PRO 2.6 DSP
Big 3
Yellow Top
The amp will be fine. You will just be sending less rms. That’s it. But if you are sending a dirty signal then the speakers will blow even though they are getting underpowered. Meaning, set the gain correctly and you are fine. This can be done with a smd dd1. Don’t cheap out if you want your gear to last. Buy a dd1.
:guido:
Do the dedicated tweeter amp. If you parallel the tweeters with the other 2 speakers, the tweeters will get the bulk of the power. If you run the amp 4 channel, the tweet will be getting more than 2x RMS and your other speakers will be missing out on lots of power.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
  • Who's Online   0 Members, 0 Anonymous, 970 Guests (See full list)
