SesameCreeps Posted July 2, 2020 Report Posted July 2, 2020 so on an amplifier(350a fuse recommended) that has dual power inputs, thats a 350a fuse on each wire correct?
Dafaseles Posted July 2, 2020 Report Posted July 2, 2020 54 minutes ago, SesameCreeps said: so on an amplifier(350a fuse recommended) that has dual power inputs, thats a 350a fuse on each wire correct? It might depend on the manufacturer. I'm going to be running amps with dual positive and negative inputs that suggest 400a fuses. But when asked, the manufacturer actually said if you're running 2 separate positions, then 200a each 1/0 cable is good. I guess maybe if you where running 1 cable through a fuse, then to an unfused distribution block, then they recommend the 400a. But different manufacturers might have a different meaning. 2011 Chevy Silverado under construction My build log here. Check it out!
SesameCreeps Posted July 2, 2020 Author Report Posted July 2, 2020 interesting. ill bust out the owners manual for my amp n see what it says.
BassMunky Posted July 2, 2020 Report Posted July 2, 2020 Yesss Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
