what about my other questions? if you see the rms of an amp, is that the rms @ 12volt or 14.4? Is there a certain universal test voltage?
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
some are rated at 12v some are rated at 14.4
DC.jpgDC POWER
what if it doesnt say is theree one thats safe to assume?
Some rated at 12, 12.5, 12.8, 13.8, 14, 16, 17 volt. Best way if it's not listed and you don't know anyone with experience on a particular amp, then call the manufacturer or check their website.
Ok guys, here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT!
This is from a quote on the termpro fourum.
DC.jpgDC POWER
so its safe to assume w/ a 240 amp alternator, and a 12volt battery under the hood, it will make 2000+ watts? :blink:
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
and might shit the bed because of lack of voltage
DC.jpgDC POWER
well if i was to run this amp, would you recommend an extra batery, like a kinetik 2000? and if i was to get 1 would it up my voltage near 14volts?
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
rated at 14.4v and recommends an inline 300amp fuse.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
or just look on RoE somewhere....there's a tool that calculates your target output voltage of your amp. Once you have that, divide your RMS wattage by that....you should be close
  • Who's Online   0 Members, 0 Anonymous, 1882 Guests (See full list)
