Jonathan91v8 Posted October 13, 2020 Report Posted October 13, 2020 I got a 150.4 skar amp for my mids and highs. On the skar website it says the inputs are for 4ga wire. Would running a 2ga or 1/0 wire around 25ft be an over kill? Or should i just save a little bit of money and just get tbe 4ga?
Dafaseles Posted October 13, 2020 Report Posted October 13, 2020 They make aftermarket inputs that you put into the amplifier inputs and you can put larger gauge wire into the amplifier. People do it all the time. As long as you still use the proper fuses, there won't be a problem https://skyhighcaraudio.com/pair-1-0-to-4ga-amp-inputs-w-heat-shrink/ 2011 Chevy Silverado under construction My build log here. Check it out!
Jonathan91v8 Posted October 14, 2020 Author Report Posted October 14, 2020 I have couple of those connectors. I just want to know if the 1/0 would be an over kill for this amp
Kocyandia Posted October 14, 2020 Report Posted October 14, 2020 24 minutes ago, Jonathan91v8 said: I have couple of those connectors. I just want to know if the 1/0 would be an over kill for this amp No such thing as overkill on electrical.
Dafaseles Posted October 14, 2020 Report Posted October 14, 2020 32 minutes ago, Jonathan91v8 said: I have couple of those connectors. I just want to know if the 1/0 would be an over kill for this amp Yep, like I said, as long as you still fuse the amp correctly, it can't do anything except help 2011 Chevy Silverado under construction My build log here. Check it out!
