I am upgrading, and need help on the wiring.
1/0 all the way?
what distribution blocks?
2nd Battery?
2nd Alt?
Not wanting to spend too much money for the wiring. Just want good results.
Clarion ProAudio VRX755VD
Infinity Perfects 6.1-front
Infinity Perfects 5.1 -rear
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
Pair of Memphis tweets
New Build In The Works
Ditch the cap, 2nd battery, wire all the amps to the 2nd battery. No need for distro blocks, don't forget about fusing the other end of the wire before the battery, don't need your ride catching on fire if something shorts out.
why is there a 1500 and a 750 watt mono amp?
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
im upgrading. have the 1500.1 and 2 subs allready, and getting another sub, so im getting a 750.1. not in the same chamber.
I meant to add the 150amp fuse that the 1500.1 comes with
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
how would I wire it up without a distribution block when i only have one run of 1/0 coming from the battery
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
What kind of battery are you getting?
You could make a copper or aluminum bus bar too.
yellow top
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
he was saying to get a 2nd battery put it in the back then run all you hots off the battery.then no need for distroblock
dont you have to fuse every wire off the battery in the back tho?
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
adding 2nd battery in the back, having 3 ring terminals off of the 2nd battery, fused in between each amp only if amp uses external fuses.
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
  • Who's Online   0 Members, 0 Anonymous, 4539 Guests (See full list)
