need help on a new amp!!
punchman
right i have 1 kicker cvr12 running off a little kicker kx200.2 amp. i know im not nearly getting the whole
potential of my sub. what amp should i get & how big of a difference will it make? thanks
2 15" Kicker L7's + Hifonics BXI 2006
How much are you willing to spend for an amp? What's your budget like?
About the difference: Yes, if you get a more powerful amp it WILL make a difference.
I assume that right now you are bridging the amp to both coils of the sub (wired in series for a 4 ohm load) and getting about 200 watts. You're underpowering the sub by a good bit.
A 450 ~ 500 Watt @ 1ohm would do you good.
i was looking at the rockford fosgate p6002 amplifier, since i work at bestbuy i could get the amp at almost half price which
is 250ish.....
what amp would you say is good for the cvr
Generally, Rockford Fosgate is a more desirable  brand than hifonics, but this amp is a class A/B amp. It will be more inefficient than the hifonics which is a class D. But it will have less distortion. Distortion you shouldn't worry about since you'll be using it for bass and will not be able to detect it.
I say go with the hifonics. It's cheaper, easier on your alternator and has more than enough clean power for that sub.
  • Who's Online   0 Members, 0 Anonymous, 1500 Guests (See full list)
