2018 golf R - upgrading "Premium" fender audio system
22 minutes ago, BboyTaktix said:
I was thinking about it and jeeze, can’t I just wire the second left set of wires directly to the terminal posts on the side of the box ?!?! - result in the same and way cleaner. So basically two sets of wires coming from terminal posts - one set to each sub.
Yeah, that's the same as the distribution block idea. Just using the posts as distribution blocks.
Got the box finished up finally (minus the carpetting)
Re-routed wiring so each sub has their own cables - much cleaner.
img_0789-jpeg.318819
img_0788-jpeg.318820
Then made some finger grab holes in the top piece in order to be able to lift out of trunk floor. Works well.
img_0790-jpeg.318822
img_0791-jpeg.318821
Made grooves in the side where box will be sitting on OEM floor sides, and also serves for me to cleanly wrap carpet around and tuck behind.
img_0792-jpeg.318824
img_0793-jpeg.318823
Due to wanting the fitment being perfect, I decided to put glue and attatch the top to the box inside the trunk. This would allow me to align the box with the top exactly how it should be, put some finishing nails in to hold it together then remove the box. Protected the car with tape and rags of course.
img_0794-jpeg.318825
2018 Golf R - Stealth SQ system build - C508GTI front (active), 2x Pioneer Z10LS4, Zapco DSPZ8, Clarion DPX11551 (Mono amp), Pioneer GM-D8604 (front stage amp), Pioneer GM-A3702 (rear fill amp)
SOLD! 2011 Subaru STI - 'modest' passive sq system - JBL p660c component (front) JBL P662 (rear) JBL W10GTI (sealed enclosure) 4ch JBL GO1004 (150RMSx4), Clarion DPX11551 mono amp (+-1200RMS@3ohms)
YAY it worked - with one small issue...
img_0797-jpeg.318826
So to perfectly align everything, i thought it would be wise to put the two M10 bolts in behind the box, connecting the amp rack to the box using some M10 threaded inserts. Well, after securing the top to the box, I got too excited and tried to remove the box. Now you will know what happens when M10 threaded inserts get ripped out of their location due to impatient builders;
img_0795-jpeg.318827
img_0796-jpeg.318828
So, I decided this could happen again and not worth the trouble. I then flush trimmed that little surface with the M10 inserts out and now the back of the box is perfectly flat/flush.
The other "issue" I noticed was that, despite my patience and medium woodworking skills, I had managed to still have some tiny gaps between the top of the box and the walls. When I shined light I could see the light from the other side.  This could not be left as I wanted the box perfectly sealed. So, I carefully used my hand/index finger inside the box  with some sealant through the subwoofer cut-outs and applied to all corners between top of box and walls. Now there should be no gaps left un-sealed. Some photos of the results;
img_0806-jpeg.318843
img_0805-jpeg.318842
img_0807-jpeg.318844
img_0810-jpeg.318845
How did you go about getting those nice, straight, deep grooves on a side with a bend in it?
OK let me try my best to explain through text - hard without demonstrating.
So I did these "Grooves" before I attached the top. Basically I took a straight spare piece of MDF and clamped it tot he piece. I used a straight router bit (the one that cuts on the top and no bearing), adjusted it to cut at about 3/16in depth,  and used my router loose, using the spare straight spare piece of MDF as a guide for my router's base plate. Once I made one groove all the way along the furthest in, I then moved the straight spare piece a little bit out towards the edge, and then repeated the process. The passes got shorter and shorter as the piece was already curved from before.
Hopefully that makes sense to you!
More progress today...quite happy with how things are coming along.
First thing I did was finalize the mounting for the top amp rack board. I decided the best way to make it solid was to put two little tabs on the back of the sub box (first photo) and one support at the back on the bottom rack, on which I would put two threaded inserts to hold the top and bottom racks together (but not the sub box!)
img_0835-jpeg.318870
img_0836-jpeg.318869
Once I was happy with that, I started permanently mounting all the equipment on the top and bottom amp rack.
img_0833-jpeg.318871
img_0834-jpeg.318872
I was then going to start routing the RCA cables but I realized that 6 footers I purchased were too long and I didn't want to deal with all the slack. I had one three foot but I would need at least two more (for zapco to two top amps) so I figured I would wait until I went back to the store to get 3-footers instead. Plus I was unsure of how to cleanly run the wires, whether to drill more holes and go down then up, or just use the slot at the front I made to go down, roll excess under then come back up. Since I was not too sure and didn't have cables in hand, I moved onto another area of the project; THE UNDER-HOOD FUSE BOX BRACKET.
Since the golf R engine has quite a lot going on, I had been struggling to find a good area to properly secure the bracket. I knew I wanted the fuse holder to be beside the battery, ideally in between battery and the ECU (to the right of it). So I used cardboard to make a rough template and see how it came out. I liked it, so I cut it out of ABS plastic;
img_0824-jpeg.318874
img_0825-jpeg.318873
Used a butane torch to bend it at the two areas I needed, turned out better than I expected. This butane torch really came in handy for this and for soldering 10GA and larger wire terminals to the wires.
img_0826-jpeg.318876
img_0827-jpeg.318875
img_0828-jpeg.318877
Then I drilled and tapped two mounting holes for the fuse holder and installed it in the engine bay - Although it isn't perfect, I am pretty happy with the look - not too in your face but clean, at least in my opinion!
img_0830-jpeg.318879
img_0829-jpeg.318880
img_0831-jpeg.318878
some photos of all the gear in the car after all this - you can see the top amp rack, the equipment is a little higher than the top of the sub box, which is fine - I plan on doing a stepped floor - the sub box beauty panel is in the third and fourth picture, the amps stick up less than 3/4inch beyond that.
img_0838-jpeg.318882
img_0837-jpeg.318881
img_0841-jpeg.318885
img_0843-jpeg.318884
img_0842-jpeg.318883
Finally, I also got a little wiring done on the lower rack. Attempting the cleanest possible using ferrules and shrink wrap. I'm liking this method a lot.
img_0850-jpeg.318894
img_0849-jpeg.318893
img_0851-jpeg.318892
img_0846-jpeg.318891
img_0844-jpeg.318890
img_0847-jpeg.318889
img_0848-jpeg.318888
img_0845-jpeg.318887
