10 minutes ago, Never Enough Bass said:
Shitty I get it all in turn it on and now the power light turns on then it switches to the clip light then it switches to the protect light flashes 3 times then does it all over again so idk what happened but I'm gonna have to figure it out later
I looked online to see if I could find the owners manual to the SIA-3500D, I couldn't....
But check the troubleshooting part of the manual, or, better yet, it might have a specific section on the lights and what different patterns mean. That's where I would start
Didn't come with a manual but I'll msg sundown and ask them it was really sad disappointed and I'm grounded to the battery
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
No manual?
Yea no manual I msgd sundown hopefully the respond back before I have to work tmw
06 Charger
Pioneer double din
Xs power d3400
You can download the manual off sundown.  Amplifier Goes Into Protection
 Check shorts on speaker wires or open coil.
 Check input voltage from RCA, if DC signal is over 4 volts, the amplifier will go into protect. Remove
and reset the power to the unit to check if it will turn on.
 Check impedance to make sure it’s over the minimum load, see the specification charts in this manual
for the minimums of your specific amp.
 Check input voltage. The amplifiers covered in this manual have a working range of 10.5 to 15.5 volts.
 Check chassis ground and remote using same ground.
This is also from the manual Note- The PWR, CLIP, and PRT leds will flash as a test when the amp is first powered on.
I looked, I couldn't find the damn manual lol. But that was exactly what I was looking for. Thank you! And I'm sure @Never Enough Bassthanks you too!
You go to amplifiers click on the sia-3500. Scroll down to product manual. When you download it, it will say sbf, but the sia-3500 is in the same manual.
Yea thanks I'm gonna check it out today I know it test like that but this just repeats over and over
06 Charger
Pioneer double din
Xs power d3400
My volt meter is hooked up straight to the amp I'm seeing 14.4v and .y ground is hooked straight to the battery
06 Charger
Pioneer double din
Xs power d3400
So my sfb 1500 works but my 3500 is still doing the same thing
06 Charger
Pioneer double din
Xs power d3400
