How about that top bolt above it in the pic
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
No. You want to stay away from anywhere that looks like it might be welded. At least in the picture it looks that way
No that's the bolt that the backrest is supposed to go on
06 Charger
Pioneer double din
Xs power d3400
What about a different seat belt bolt
06 Charger
Pioneer double din
Xs power d3400
Think about it this way. You see these big, huge SPL systems with their big huge batteries? Where are their amps grounded? Look close, they ground them to the batteries. Then ground the mess out of the batteries to the frame, and even sometimes grounding back up to the alternator as well. In my opinion, of they do it in pro competition, I'm assuming that's the right way to do it.
Now, you're not running 10's of thousands of watts, so you don't have to go that crazy with your grounding, but I'm sure you get my point.
Yea definitely I get it I'm gonna order some more wire and get to grounding
06 Charger
Pioneer double din
Xs power d3400
Just getting out of my car and just thought about something could this happen because my headunit is turning off before my amp
06 Charger
Pioneer double din
Xs power d3400
No. Your head unit should turn off, then your power light on your amp should fade off.
Yea that's what it does
06 Charger
Pioneer double din
Xs power d3400
It's a small thump tho so I should be fine tell this wire comes right
06 Charger
Pioneer double din
Xs power d3400
