Ok so I noticed it happens when turning on too
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
7 hours ago, Never Enough Bass said:
It's a small thump tho so I should be fine tell this wire comes right
It's sending a harsh frequency to your voice coils, so it's not very good for the sub, but you should be fine. But I'm not 100% sure. I haven't heard it.
Does the pop change with whatever volume your head unit is at when it turns off? Or is it a consistent volume?
I'm not sure I always turn my volume down to about 7 8 before I turn it off it's just like a soft thump like someone tapped on my cone a little bit
06 Charger
Pioneer double din
Xs power d3400
I'd definitely keep doing that until the problem is fixed
Yea I always turn it down with all my systems it's force of habit with the climate I live in it's michigan u can get all 4 seasons in 1 day
06 Charger
Pioneer double din
Xs power d3400
Maybe I should turn it down more and see if it lowers or if it stays the same I know if I turn my head unit off with car still running it still does it
06 Charger
Pioneer double din
Xs power d3400
