35 minutes ago, Never Enough Bass said:
What kind of rca's do u have
For the 4 channel I used a nvx amp kit. And the mono I used sky high rcas. I’m pretty sure both are twisted pair and shielded.
Like @Dafaselessaid add some grounds pretty much process of elimination at this point
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Did u try grounding the high amp straight to the battery
06 Charger
Pioneer double din
Xs power d3400
I'm kinda going thru the same thing my subs thump a little when the amp turns on and off
06 Charger
Pioneer double din
Xs power d3400
Mine does too. Not very loud or anything but I notice it. I also notice it when I turn the bass knob up or down.
Yea it didn't do it with my old amp I just changed amps about 2 weeks ago and added the second battery now it does it no clue why I don't have much time to mess with it so it's going slow to find out why
06 Charger
Pioneer double din
Xs power d3400
Tried the 4 channel grounded to the battery and it still the same. Maybe even worse. I’m gonna try grounding the battery in a different spot maybe. I’m not sure
15 minutes ago, Dafaseles said:
How are your amplifiers mounted?
Mine is screwed into plastic I found what's wrong with mine 1 of my grounds is 75 ohms lol
06 Charger
Pioneer double din
Xs power d3400
