Quick question
Ok so I got my box design but my max dimensions aren't that great a little on the small side it's 32w×15.5h×24d should I invert my subs to save on the .42 displacement of the subs
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
After you get the enclosure built, try the sub both ways. See which way sounds better to you
I just know that with all the displacements the box will only be 3.60 cuft in a common chamber box and sundown u series calls for 2 cu per sub I might make the bracing smaller that the design to help with this to
06 Charger
Pioneer double din
Xs power d3400
I'm probably gonna make my braces like a picture window without the middles to add to it to but I'm not sure the design I had made says it's 3.60 cu ft but sundown says I need 2 per sub
06 Charger
Pioneer double din
Xs power d3400
And i always go larger than oem spec.
Where abouts is the tuning?
32hz but those are my max dimensions it's a common chamber box don't know if that matters but I'm trying to make it work
06 Charger
Pioneer double din
Xs power d3400
  • Who's Online   1 Member, 0 Anonymous, 838 Guests (See full list)
