Anyone have any recommendations for a good wiring kit for a single 12. Looking for 4 guage. I was looking at the knu brand but people were saying it’s not 100% copper. Any ideas on what to get?
Knukonceptz is legit. I don't know who told you that. They do sell both OFC and CCA, but as long as you make sure you get the OFC, you're good.
SHCA has really good cable, so does Sundown. HiFi Vega has a whole series of videos on YouTube comparing different brands of 1/0 cable. Pretty interesting
Knu kolossus is great wire
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
To be truthful I saw it in the reviews. Thanks a lot for your insight, i appreciate it. Center console build starts Thursday.. ill make sure to post. Also, what is considered a "good" inline fuse for the power wire. A local audio shop sells one for 60$, and Rockford sells one for 11$. Why is one so much higher than the other? Should I get a higher pricing fuse?
Any fuse will work as long as it is rated to your amp
06 Charger
Pioneer double din
Xs power d3400
Some fuses are plastic, which are usually between $4-$10 a piece. Then you have ceramic fuses which can jump up into the $20 a piece range. The ceramic style is better because of its tolerance to heat as opposed to plastic.
In my opinion though, if you're not running some crazy huge system, that can generate a lot of excess heat, plastic ANL fuses work just fine. Sky High Car Audio has their own fuses. I want to say they're $4 a piece. Maybe even less right now. I think they're running a sale
Alright thanks, I actually also just ordered the Knu Kolassus 4 gauge wiring kit OFC. And your right, watched a couple videos and did some research, glad I went with them over some of the cheap amazon kits.
I think the kit will come with a fuse block
06 Charger
Pioneer double din
Xs power d3400
