Maybe try it watch your voltage
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
Like @Never Enough Bassbass said, watch your voltage.
That amount of power is pushing it, though not unheard of. Make sure the big 3 is done as well.
I recommend getting an in dash volt meter as well so you can monitor your voltage at your amplifier. If it gets too low, you can turn it down, or think about getting a second battery, but you'll be able to remedy the situation before you damage anything.
I've also heard from people that the full bridge amplifiers don't like a lot of fluctuations in power and can cause them to struggle, and eventually fail. So again, you can try it, but watch your voltage.
  • Who's Online   1 Member, 0 Anonymous, 560 Guests (See full list)
