Zvx on sundown 3500.1 clipping help
Really those amps do not like voltage drop at all
06 Charger
Pioneer double din
Pioneer 6.5 and 6×9's
0 ga knukoncept kolossus wire
Big 3 same wire ^ 1 run
8g karma ss speaker wire
Sundown sia 3500d at 1ohm
2 Sundown U series 12's
Xs power d3400
Trying to find a ho alt
On 3/22/2022 at 10:27 AM, Thompson358 said:
I will try doing that again when I get home but that’s what my friend did for me lastnight and I just can’t get it to hit any harder without the clip light blinking do you think my SIA3500.1 could be messed up I’m super worried about it because I don’t have the money to buy another rn
Your electrical is shit
06 Charger
Pioneer double din
Xs power d3400
We’ll I have a 390amp alternator now 2 runs of 0 guage And I still have this clipping problem at the same volume when I had the stock alt without a big 3
So after doing the alternator and everything. I have no voltage drop no dimming everything looks and sounds great just at high volume my clip light stays on and sometimes if it hits a super low note the red light on the amp will flash but it sounds great i don’t hear any distortion should I be worried about it or should I let it slam?
Where do you set the volume on your phone when you listen to music?
The volume on my phone is all the way up the sub has some glue that dried and looks like it was running down the backside of the cone idk if that’s a bad thing but I’m going to test it today to make sure it’s fine
See what happens if you turn your phone down one or 2 clicks. You might be able to turn the gain or volume up more and get more volume.
Like I said before, using a DD-1 with an I phone, the signal clips all the way up, but is clean one click down. I haven't tried with an android yet though.
Fuck it let it slam I'm about 2 tourcher test my sia 3500 see if I can blow it up time for a new amp anyways it doesn't push 2 u series like I thought it would don't get me wrong my vision be blurry and my ears pop but it's just not enough lmao
06 Charger
Pioneer double din
Xs power d3400
