sonic purity Posted May 18, 2008 Report Posted May 18, 2008 Will the T2000 run at 16 volts? I cant find anything about it. n2caraudio.com
banginAltima Posted May 18, 2008 Report Posted May 18, 2008 Bad things will happen if you run at 16 volts.... If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
sonic purity Posted May 18, 2008 Author Report Posted May 18, 2008 Bad things will happen if you run at 16 volts.... I was just wondering if it was meant to run at 16 volts or not. I guess not. I will stay with sundown then n2caraudio.com
ISO Posted May 18, 2008 Report Posted May 18, 2008 Bad things will happen if you run at 16 volts.... They are a consumer line of product. But they are are rated at 2000 watts at 12.5 volt, so why push it. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
ISO Posted May 18, 2008 Report Posted May 18, 2008 Why do you need to run at 16 volts? You have looked at how much money that would cost, unless you are doing major DB events rite. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
Pitbullx Posted May 18, 2008 Report Posted May 18, 2008 need to have them modified to run at 16v Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
dmanson Posted May 18, 2008 Report Posted May 18, 2008 if i'm not mistaken, they shouldn't be ran no higher than 15 volts. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
sactownstang Posted May 18, 2008 Report Posted May 18, 2008 Don't think the T2001 can be modified or so I was told in the past. I have t4001 amps that are 18v, for spl use...
