I have a serious Voltage Problem....my voltage sits at 12.5 on IDLE :S i have 2 batteries install a HC2400 n my stock battery.with engine off about 11.9-12.0 volts Do i need more batteries still?
Edited by Browne
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Pioneer AVH-P4900DVD
Clarion EQS746
AudioControl EPIC160
Kinetik HC2400
do you have a HO alternator to keep them both charged to the fullest?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
12.5volts at idle means your alternator isn't charging properly. Any stock charging system should put out 14+volts. This is also causing a low voltage condition with your batteries since they aren't getting a good charge. Those batteries should hold 12.9v at rest.
Yes i have a 200amp ALT
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
rev the engine up to 2000rpm then take ur reading
should be at 12.8 with car off/idle if alt doesnt kick in right away
if it goes below 12 when u rev it ur alt isnt working
edit* and get rid of stock bat for biggest kinetik that fits
mixing bats especially wet and dry cell causes uneven charging and usually the larger bat "steals" amperage from the smaller bat
Edited by decafcappucino
wen i rev it reads about 13.9 - 14.0 sumtimes 14.2volts
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
well it should go to 14.4 without music playing
but it is working....
i dont know the exact problem but the alt is working if the voltage goes up when u rev it
try disconnecting 2400 and see what u get, and if you can, disconnect stock and temporarily connect 2400 and check again
most HO alts dont "turn on" until 800-1000 rpm, and provide peak output at ~1500-2000rpm
Without the Kinetik i was reading 13.5 or sumthing like that wen reving.... neva tried the hc2400 alone....buh i kno wen i first got it it read 13.0volts out of the box
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
with 200a alt and stock batt and no kinetik u should see the highest number, since ur charging the least amount of batts
are u measuing at the stock bat location when ur taking these readings? or kinetik in the back
at the stock bat...and i also have a voltage meter inside the jeep...The AudioControl EPIC160
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
  • Who's Online   0 Members, 0 Anonymous, 2852 Guests (See full list)
