Fi Car Audio
New 18" Btl Problem
greg662
well the bass knob has a clipping light on it and it hasn't came on yet. if i turn my bass down on my cd player the bass is little to nothing if i turn the gain to about 4v the bass is little to nothin same if i turn the loud off. and thats with my cd player all the way up. i have a pioneer cd player cant remember the model number its not the best but its not the cheapest either and the guy that built it said its 90 in. of port
2 15" DC LVL 5' crescendo 5500 yellow top under the hood and two xs power d3100
Big three upgrade
Rockford Fosgate T162S components in front
Rockford Fosgate T152 in the back
Dynamat everywhere
90 sqaure inches is about right.
how many preamp out puts are on your cd player? 3, 2, 1? are you using the preamp out put for the sub channel, and not plugged into a front or rear channel?
is there a sub volume in the menus of the cd player where you can turn it up?
What ohm voice coils do you have on your sub?, how do you have the sub wired up. Chances are its going to be something really cheezy why your not having the bass you need.
Im starting to think that your not using the right set of preamp outputs if you need to have loud and bass all the way up to here bass. Thats not right at all.
Thats what i am thinking its just some lil thing that i cant find but i only have one set of rca outputs
could it be that the cd player is bad bc i am about to upgrade my cd player anyways?
and i have it wired down to 1 ohm
Big three upgrade
Dynamat everywhere
That maybe most of your problem, its not really a sub output, not that it matters too much, but compaired to a newer headunit you will get sub controls such as volume, crossover settings etc. Im also guessing that your output voltage is really low too since it seems to be a semi cheaper or older unit with only one preamp output, meaning you should have to have your amp gain nearly all the way up, but not fully.
Can you go out and look at the model number of the cd player? it should say someplace on the face of it.
Pioneer
DEH-P2900MP
yeah its pretty cheap one but would it really make that big of a difference it worked just fine for my l7 system put it like this one of my friends has a cheap memphis 15 with a 500watt amp and he is beating harder than me.
and i dont know how to upload pics if someone can tell me how i can
Big three upgrade
Dynamat everywhere
my 18" BTL is in 6.5 cubes after all displacement and tuned to 28 hz.
i lose alot of high end output but the lows are NASTY!!!!!!
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
try a head unit with 5 volt pre-outs ;)
have you checked the gain and filters and x-overs on the amp??
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
5 volt deck is that answer? If only things were that easy....
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
i noticed a HUGE! difference when i went from 5 to 2 volts no matter how the gain was set.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
  • Who's Online   1 Member, 0 Anonymous, 502 Guests (See full list)
