hey guys I'm finally ordering a 12 in rockford t1 and planning on running it on a hifonics bxi 1206d and was wondering if I should get d2 or d4? I dont understand the ohm configurations completly.
Also I was wondering if I should go with the 1208d instead. I dont know if theres a difference or not any recommendation?
go to rockfords web site and look at the woofer wiring wizard.
The New - 2002 Acura Rsx (work in progress)Eclipse AVN7000Eclipse 4 Channel4 Polk Audio Db 6.5 (soon to be changed)T500.1Punch 3 15"- The (old) System - 94 GMC Sonoma Ext. CabH/U - Pioneer Avic D3Eclipse 4 Channel Amp2 MB Quart DUA 216 6.5 components2 Polk Momo 4x10s1 RF Power T5001bd2 RF P315D4's 5 cubes net @ 35hzPowermaster D1200 Battery
Get a D2 if you're only running (1) 12, get a D4 if you plan on running 2.
just a suggestion if you have the space get 2 rk t1's since they are 500 watts rms each or if your having space issues you can get 1 t2 rk they are 1000 watts rms..
heres what your amp does and different ohms
# RMS @ 4-Ohm: 1 x 450-Watt
# RMS @ 2-Ohm: 1 x 900-Watt
# RMS @ 1-Ohm: 1 x 1200-Watt
I was going to get a single t1 12 because thats all I really have space for. the t2 is out of my price range. I found the t1 for 160 shipped. and its in a 89 mustang hatch so it should be good enough for a daily set up any thoughts? also since I'm most likely only running one should i get a different amp?
is there a difference between the 1206d and the 1208d?
the last two numeric digits are the year they were made. go with the 08d
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i half agree with that. a dual 2 wither he will get a 1 or 4 ohm laod. 1 will be way too much and 4 wont be enough. heres what you should so:
go with a dual 4 ohm that way you can wire it down to 2 ohm and get a good amount of power with out being TOO much over. also you can add another and they will get near perfect power to them
NoFearX18 said:
trainman0978 said:
o all right. I should have thought about that.
any ideas if thats a good amp for a single t1 12? and even if the t1 12 would be enough? I know you can never really have enough but for a budget set up with good sound quality? and running of that amp.
whats your budget/space/ and what kind of sound are you looking for?
My DD has two Typr R 12's running off a Bxi1206 and its slams pretty decent. Its not a bad amp. Def. go with the dual 4's and squeeze two 12's in that hatch. Theres plenty of space. I know, I used to have one with two! ;)
  • Who's Online   1 Member, 1 Anonymous (See full list)
