Okay so this is a STPUID quesiton but why would you guys want more than 1 battery? Everyone has it and I'm just wondering. I mean, the system is only playing when the car is ON so wouldn't alternators cover it? Wouldn't the only reason to have >1 battery be to play it for hours when the car is off?
Haha thanks
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
Haha thanks
the fact you can play it longer with the car off is a plus..........BUT its so you can stay at peak volume for longer amount of times...i.e. steve has enuf batteries to build a house and 4 alternators (plenty of power) and he even has a voltage drop...he revs his engine to get the most out of his system and keep the batteries up to full.....they keep your amps putting out the most power........you have one 12v battery that stays at 14 volts full charged.... 2 of them will help keep your system stay up to full capacity longer then say one with just 1 battery......hell w87will has a 300 amp iraggi alt and just 1 battery and he says that he isnt seing full capacity because that battery cant re-charge fast enuf...multiply batteries gets rid of that problem and keeps your system better (might not make sence, but it is all good)
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
It all depends on the current demands of a system. Most small systems do ok with a single upgraded battery. Add a little amperage demanding multi-amp system to a car and then you'll have to consider what's best for feeding it. I say anything over 100 amps in current draw requires some attention in the charging / storage department.
okay so i guess the main reason is the battery cannot charge fast enough if you only have one? i'm about to upgrade my electrical so just wondering
~Matthew
Long story short. It's harder to drain 4 batteries then it is to drain 1. So you can keep a higher voltage for a longer period of time when pulling some massive power.
Rollerz Only - Sacramento Chapter. 6 Time Lowrider Magazine club of the year
94 Xploder on 22s - Gutted for now...
87 Cadillac Fleetwood Brougham on hydros, fully euroed out Tookie blue
*ROLLERZ ONLY MAFIA*
Crankin the volume knob and hittin switches.
http://www.rollerzonly.com
Big systems draw big current. I'm not going to rely solely on an alternator to feed my power-hungry babies. The more batteries the better in my eyes.
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
ok cool, makes sense
~Matthew
Most alts cant keep up to current draw of a stereo; 70 amp alt @ 14.4v = 1000 watts (at 100% efficiency) So anything over that will draw from the battery.
My amp draws over 500amps (I beleive 545 but can't remember right now). My alternator outputs 350amp at 2k rpm.
The alternator runs the system when the vehicle (in my case a van) is running. When the amp hits a good bass note it'll cause too much of a demand on the alternator. The battery then kicks in to account for the extra power needed. Once the bass note is done, the alternator then turns around and starts charging the battery.
Even with my 16 volt battery bank I am seeing a voltage drop. 14 8 volt 1000amp batteries wired to 16volts should, if my math is correct, be roughly 7000amps. At idle my voltage will drop down to 14.5 volts (not really good for a 16volt system). At 2k rpm, the voltage stays at 15.9 constant.
In short, it take power to make power.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
got it. thanks guys i was just wondering but i think i get it now
~Matthew
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
