keep grinding away ;) but keep checking every lil bit so you dont go too big
yeah its about an 1/8 too small on the side i guess
i took out the radius as well, which makes the box itself look worse, but you would never know with the subs in
i dont plan on driving around without subs in the box. ha
Clarion ProAudio VRX755VD
Infinity Perfects 6.1-front
Infinity Perfects 5.1 -rear
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
Pair of Memphis tweets
New Build In The Works
i drilled a hole in the corners, and in the midpoints, to show where my marks are before i cut out the corners, assuming the hole saw would cut the paper like it did, then got a metal straight edge and a razor blade, and drew a line with it
Thats the way without a router...just takes to much time
well i have a router, its just the bits i have werent doing anything for the mdf. grinding is so boring. its just smoking up the shop
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
i just finished fiberglassing the inside of the box. but i ran into a delima
how should i make my terminals?
metal bolt with nuts on each side,
or just run speaker cable to the subs and caulk it so no air leaks?
-JW
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
the third L715 will be in tomorrow, along with the zx750.1 . hopefully i can get this thing wired up in under 2 days. im still looking for a battery to go under my seats in the back, and i need som 1/0 power to run. hopefully i will find some tomorrow.
but any suggestions on speaker terminals?
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
bump
hopefully i can get this done in the morning?
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
I would use the bolt and nuts. that's what i use on my installs. works really well. good luck.
nutz'n boltz ftw for that setup.
-Drew
uhoh_45 said:
would any type of nuts and bolts work, or would it need to be a certain type or finish?
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
