mel80 Posted September 4, 2023 Author Report Share Posted September 4, 2023 got all the bracing in and done and reinstaleld the front baffle its now permantly attached and sealed , while i was at it i decided to invert the top center sub just for looks , not sure if im going to leave it inverted hence why i just pulled the speaker wire out of the port to hook it up for now . the motor is dangerously close to drivers and passenger heads , im a lil owrried somone might smack there head on it in an accident or say in an panic/emergency braking situation so not sure if im going to leave it inverted, ill do some testing with it this way in 2 days when the glue and edhesives i used are fully cured 1 Quote Link to comment Share on other sites More sharing options...
Wifebtr Posted September 6, 2023 Report Share Posted September 6, 2023 Right on. A dude on Caraudio.com built a walled car (I think) with Audio Legion subs. Said he got a great deal on them. Looks like it bump do! Quote Link to comment Share on other sites More sharing options...
mel80 Posted September 8, 2023 Author Report Share Posted September 8, 2023 it deff does bump , find out just how much in 10 days when i head down to vegas for bass wars , unfortunatly i have so much to do still i wiont have the time to actually seal the wall off to the b pillars/roof/floor Quote Link to comment Share on other sites More sharing options...
mel80 Posted September 12, 2023 Author Report Share Posted September 12, 2023 seats are back in , lithium is installed back in the trunk cleaned up the amp wiring , few minor odds and ends to take care of before this weeknd Quote Link to comment Share on other sites More sharing options...
mel80 Posted September 13, 2023 Author Report Share Posted September 13, 2023 Quote Link to comment Share on other sites More sharing options...
mel80 Posted September 18, 2023 Author Report Share Posted September 18, 2023 (edited) 1st and second in classes after i broke the wall was doing some demos in the 20-30hz range before i made my runs and blew the bottom seam on the back wall , sheared the pocket screws glue and brace right in half its all dbl walled too so now i gota figur eout how to repair it Edited September 18, 2023 by mel80 Quote Link to comment Share on other sites More sharing options...
killerc998 Posted September 19, 2023 Report Share Posted September 19, 2023 Might be time to use some metal along brackets along the long sides along with 90s to add more surface area to glue to. Quote Link to comment Share on other sites More sharing options...
mel80 Posted September 20, 2023 Author Report Share Posted September 20, 2023 On 9/19/2023 at 6:32 AM, killerc998 said: Might be time to use some metal along brackets along the long sides along with 90s to add more surface area to glue to. my thought/plan atm is to cut some 2x4's to glue and screw in there , the rear wall is on a 13* angle so im thinking about rippipng some 2x4's on that 13* angle and glueing/screwing them to the floor and the back wall , and i can go 2 layers high which should be plenty. Quote Link to comment Share on other sites More sharing options...
mel80 Posted October 2, 2023 Author Report Share Posted October 2, 2023 1 Quote Link to comment Share on other sites More sharing options...
mel80 Posted October 26, 2023 Author Report Share Posted October 26, 2023 (edited) been a while but heres an update wall is repaired and holding so far though i did burn up my headway bank so i havent been able to give it fuull power yet .that being said i have 296ah of lev60 on the way along weith enough headway to rebuild my bank into a 128ah bank ontop of the 296 of lev60. my next basswars even is comming up on the 4th so well see how she does im looking for atleast 5db gains over what i put up with the leaking wall last time Edited October 26, 2023 by mel80 Quote Link to comment Share on other sites More sharing options...
