2 Wolffram t1 12” woofers box help plz
OuijaEight
I’m trying to design a box for these wolffram 12” dual 2 ohm woofers.. running 2 ohm load, they are 750 rms each..  I believe they have a 2.5 coil I can’t find the t/s specs on them..
I used an app and am wondering if @Joe X can help me again..   want the box 32 to 35 hz if possible … if the box below needs too be redesigned
going in a 300 max space is 16h 38w 40d
here is what I came up with if this would be fine and not cause any issues.. please lmk
  • 3 weeks later...
2nd design looks to be ok off hand... ill run it through winisd when i get off work later tonight and ill let you know what i come up with
This page is crispy_chick3n approved.
© crispy_chick3n inc
1st design might be ok depending on amp. its a smidgen larger than recommended, but it might be ok... usually on oversized you get less playable bandwidth, but more output (louder). its also a little more risky to the subs.
  • Who's Online   1 Member, 0 Anonymous, 731 Guests (See full list)
