ISO Posted June 10, 2008 Report Posted June 10, 2008 I think you might need to check out Peripherial or DEI. I think you could find something more suited to your needs. Or take what Aaron and I have suggested and send an Email to Stinger asking the same question. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
ISO Posted June 10, 2008 Report Posted June 10, 2008 http://peripheralelectronics.com/ Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
pstone11 Posted June 10, 2008 Report Posted June 10, 2008 The cheaper of the 2 Stingers i posted will work just fine then ive used one before and it worked just fine PStone11 on here has all used one I think the same one so he might have some feedback for you on it I used the Stinger SLOCII in the GTO, it's small and worked great no problems whatsoever. Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
jmsonoma03 Posted June 10, 2008 Report Posted June 10, 2008 does your car have a factory sub if it does make sure you tag signal after the amp going to it if not tag off rear channels .make sure the rears are full range most bose systems have built in crossovers in the amp.
banginAltima Posted June 11, 2008 Author Report Posted June 11, 2008 does your car have a factory sub if it does make sure you tag signal after the amp going to it if not tag off rear channels .make sure the rears are full range most bose systems have built in crossovers in the amp. Not sure if I have a sub or not. I know it has tweeters in the A-pillar, speakers in all four doors and two in the rear deck. The factory amp is mounted under the rear deck. I have not traced wires or any thing like that. Edit: the rear deck speakers sound deeper than the rest. Not sure if its cause they are using the trunk as a box or if the amp has a crossover on them. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
bkolfo4 Posted June 11, 2008 Report Posted June 11, 2008 Pac tool model #sni-15. should be under $20 x2 I use that one for all of my installs with factory radios. NEVER had any problems. Great LOC for a great price. http://www.sonicelectronix.com/item_5264_PAC+SNI-15.html Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
