Amperage, Bus Bars, Wiring
I am starting my rebuild soon, I need some advice because Ive never built anything that needed this much power. I have a high output alt already.
Amps are rated 5,800 watts rms. I did some research and found Ill need roughly 2000A of batt to back it up.
Replacing the stock batt and adding 2 to the back will put me at roughly 2000A.
-do these numbers sound right?
-can I use bus bars on a regular 12v system?
-if I did go teh bus bar route, do I need to run B+ from the alt to the bus bar?
-would the p's and g's need to be rated for 2000A or is the load somehow split across the batts?
I got a couple more ?s just cant think of them all right now THX!
Whaaa?
2000A?
2000A = 20000w at a conservative estimate!
You might not want to run them for a long time but you could probably run that off a single Yellowtop!
- Bus bars are just lumps of metal. Yes you can use them
- You don't need a wire directly from the alt to the bus bar. As long as all the batteries are connected to it and the alt is connected to the main battery's + then you're fine.
- P's and G's? Come again :P
10.x volts fo' life!
Whaaa?
2000A?
I think P means Power and G means ground. Yes, you will want to use enough 1/0 to be rated for your amperage, but really you would need around 400-450 amps worth of Alternator to support that without voltage drop. If you don't plan on running multiple alternators, you could do a single upgraded Alternator and one battery in the back to suplement. Bus bars prolly wouldn't be necessary, cause you would only have one suplemental battery in the back.
Total RMS Minimun Total RMS Minimum
Wattage of Battery Wattage of Battery
System Current System Current
0 - 50 675 1100 - 1200 1250
50 - 100 700 1200 - 1300 1300
100 - 150 725 1300 - 1400 1350
150 - 200 750 1400 - 1500 1400
200 - 250 775 1500 - 2000 1450
250 - 300 800 2000 - 2500 1500
300 - 350 825 2500 - 3000 1550
350 - 400 850 3000 - 3500 1600
400 - 450 875 3500 - 4000 1650
450 - 500 900 4000 - 4500 1700
500 - 600 950 4500 - 5000 1750
600 - 700 1000 5000 - 6000 1850
700 - 800 1050 6000 - 7000 1850
800 - 900 1100 7000 - 8000 1900
900 - 1000 1150 8000 - 9000 1950
1000 - 1100 1200 9000 - 10000 2000
i copied this chart from this site a while back B)
yeah powers and grounds lol
I like the clean look of the bus bar as opposed to fuse blocks......and for batts I cant fit anything bigger then the stocker in the front, so if I added 2 in the back I think Id be all right
thx for the replies guys
The chart reffers to battery amperage, which is different than alternator amperage. I'm sure 2 D2400's, or probably even a single D3100 would get the job done. If you use the XSpower batteries, you wouldn't necesarily need to use bus bars, you would have 2 + and 2 - threaded holes, and you can easily stack 3 crimped ring terminals per hole. This would give you more than enough conection points for your amp, 2 grounds and alternator conection.
  • Who's Online   0 Members, 0 Anonymous, 1031 Guests (See full list)
