8 is a 2ohm load
-Drew
yup
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
question is how many amps??
your going to get an awkward ohm load with one amp on 10 or two amps on 5 each
-Drew
uhoh_45 said:
with 10 you should be able to get a 1ohm load parrellel series parrallel some thing like that :)
Some thing like that?
Some thing like that is how people blow sh!t up :rolleyes:
You can't get 1 ohm from 10 4 ohm SVC subs.
If you series the woofers in pairs it'll give you 5 8 ohm loads which you could parallel together to get 1.6 ohms at the amp if my maths works out right.
Or if you have 2 amps and good electrical you could do 2 sets of 5 subs paralleled to give 0.8 ohms to each amp.
10.x volts fo' life!
go fuck your self or something like that!!!
im gonna run all 10 on 1 rockford 1000bd amp
Im a scamming little cunt rag. i like penis, cum more penis, oh and did i mention penis.
i suck at life....
go to woofers ohm load- pinned in woofers section post 4 click on link put in 10- 4 ohms in box it comes out to 4 ohms .you can also parallel 4 speakers together for a 1ohm load then parallel 4 more for a 1 ohm load then series them to 2 ohm.then parallel the last two for a 2ohm load parallel the 2- 2ohm loads together for a 1OHM LOAD can be done do the math instead of going to jl website which said you can get a 1.6 or a .4ohm load . there is many ways to wire subs final impedence may be off subs arent a true 4 ohm. B)B)
Oh hooray. Did you ever do electronics at school?
Lets take a quick look at this...
Say we have a 2500wrms @ 1 ohm amp.
Thats 50A @ 50vac
The amp sees 2 paralleled 2-ohm loads: The 8 woofers in series/parallel and the 2 paralleled woofers.
The current the amp supplies will be split between these 2 2 ohm loads (Parallel = current split, series = voltage split)
So 2 of the subs will get half the power (25A @ 50vac) and the other 8 subs will get the other 25A @ 50vac.
So you have 2 subs getting 625wrms each, then 1250wrms split between the other 8 subs.
Now we have 25A @ 50vac going into the 8 subs in series/parallel.
Split the current again for the paralleling: 12.5A @ 50vac for each bunch of 4 subs - that's 625wrms per 4
Divide the power between the 4 subs and what do we get?
156.25wrms per sub.
So, we have 2 subs getting 625wrms each and the other 8 subs getting 156.25w each. Good going :rolleyes:
Or, we could wire it sensibly, and get the same power to each sub.
Thus, may I suggest that you stop giving bad advice when you don't know what you're talking about, before somebody listens to it and blows their shit up. What if his subs were 250wrms on a 2500wrms amp and he wired them up like you say?
Back to the posters original question, with a RF 1000 your best option is to wire up 5 sets of 2 subs in series then parallel them all up.
Gives you 1.6 ohms at the amp which is the lowest safe load you can really do.
Edited by Boon
