Whenever I bridge my 1000/2 amp it puts itself into protect mode how can I fix this
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
dont drop your ohm load so low!!!
what ohm load can the amp handle and what ohms are your subs?
Stop bridging your amp. Problem fixed
yep my friend did the same thing but didnt listen to me.....stop brid and check what ohm load is stable for your amp at bridgeing...it is very possible that you are doing this at an unstable ohm load so stop bc u overheat it
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
Well my amp is 2 Ohm bridged I think but i'm not sure what my speakers are I know they are all single voice coils but how would i check them to see what ohm the speakers are
1997 4 Runner
Alpine CDA-9886
pull the speaker out of the box and look on it...it should say on the back of the speaker somewhere...
Also...most amps are not stable @ 2 ohms bridged...Yours may not be make sure to check the specs on the manufacture's site...
Eclipse cd7000
well i have pulled all 4 of my speakers out of the boxes before and none of them have anything on them, no model number no information nothing
1997 4 Runner
Alpine CDA-9886
Well if you are running four speakers bridged on that amp you are certain to go into protect...
You could get a DMM and check what impedance they are with a digital multimeter..thats about all u can do if you can get no info on the speakers...
Eclipse cd7000
Well i'm actually running 2 amps 1 for each pair of speakers, but right now ive just got each speaker run on its own channel so I guess i'll just leave well enough alone for now until I get my new DC lvl 4's
1997 4 Runner
Alpine CDA-9886
Your amp is not 2 ohm stable when bridged.
It's a 2-channel class a/b... and not some godly swedish one... if it doesn't protect it'll get really really hot and then pop half the transistors inside.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 2284 Guests (See full list)
