Well what kinda car is the most important question?
A single 300 amp alt once HOT will lower its output because of internal heat. You should only count on 200amps at max for your output in most single alt cases due to heat (internally controlled), and the rest of your cars components. If you want 2 -4000D's and 2- 4ch amps you are looking @ well over ANY single alt /battery or ies limits. One 300amp alt and 4 big batteries might keep up for a little bit, but you will need to keep a close eye on your voltage. If the voltage drops quick then you do not have enough storage and your alt wont be able to keep up. 2-4000d and 2 -4ch amps will pull well over any alts output compacity. One alt on 4 batteries with that much draw will have a hard time keeping up. Check on the idle output if you will play at shows/demo alot most 300amp alts have a low idle output. Hope some of this helps ,good luck
MLA
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
MLA
hey thanks. ok then well its one of the iraggi alts and it says it idles at 135. so then should i try to get 2 300s then??
also thanks everyone for the input and help
2004 F150 super crew
15" fi btl
Ma Audio hk4000d
i'd do a 220 and a 300, that way you get some good idle power
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
ok the 300 says its 135 idle
and there is a 240 that is 165 idle
is that high enough? so considering the heat issue that missinglink brought up i could count on probably 340 amps driving and then 300 idle? would that be enough? the battery thing also are the yellowtops ok? or is it worth it to shell out the extra hundred for powermaster?
15" fi btl
Ma Audio hk4000d
Keep the yellowtop as a starting battery and just get some d3100 for the rear.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
What type of vehicle is it? You might be able to get a Powermaster under the hood.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
ok. 2? each one hooked to a 4 channel and hk4000d?
You would just run all your batteries together in parallel. (conect all the positive terminals together, then connect all the negative terminals to ground)
I would start with one D3100 in the back and see how it does. That's an 80lb battery, the stoutest single battery we've ever tested. (that's why we don't sell optima anymore) I'd start with one and see how it does, you can always add more later.
2004 f150.....there isnt much room under the hood. so id just put it underneath the backseat
15" fi btl
Ma Audio hk4000d
You could always mount it under the cab or the bed, there's lots of room under there. That way it isn't taking up space inside the vehicle.
  • Who's Online   0 Members, 0 Anonymous, 4261 Guests (See full list)
