Yes, I'm new, but i could use some help. 1997 silverado crew cab sub install.
ok
http://www.woofersetc.com/index.cfm?fuseac...Product_ID=3682
is that better... when i was at best buy I installed one of these with 2 off brand subs, and it hit kinda of hard. It will get you enough bass i believe
A blow through box(cutting the cab) is a pain to do. I've had a friend do one before and he could never get it to stop leaking. Ray may say different. I belive he has alot of experance with your type trucks
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
or run some 8's ;D
This in an '06 2500HD quad cab duramax diesel..yet to be finished.
ZERO SPACE!
amps are:
KAC 8152D SUBS
KAC 8452 Mids (4chann)
shit,  I could prolly fill behind the seat and under the seat with 8's,  but are they gunna give me the low end of 2 12's?  realistically?
also,  I've seen those "universal"  style boxes that hold 2 10's that go behind seat.  Could I just make a box similar to that,  that would fit truck better, and get some decent sound?  I actuall was thinkin about making an "L" shaped box, that would go from under seat, to behind the seat.  Mount the 10's (?) behind seat, and have ports come out under seat?  sound like that would work?
4 8's behind the seat.
there is room  hell my very good friend has the same truck, and i put 4 re 8's, back there it bumps ok..
you cant go looking for alot if your not gonna give up room.
hell here is a truck 04 quad cab, with even less room than you have. also 4 re 8's,(ported)
or the link to the whole truck
http://fresnoracing.ipbhost.com/index.php?...?showtopic=9857
might be able to squeeze in some 10s
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Yea I agree w/ the L7 8's I actually have 3 of em to replace those 2 8's in the truck once the weather's better and finals are over.
Nice work as usual RAY.
Any ##'s on the truck just as reference of how loud it could be w/ 8's done right?
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
So I did some measureing,  and it looks like I have about 8 inches in height,  but I guess I could allways space the seat bracket up an inch if need be.  Also looks like about 12 inches deep, and I;m pretty sure I can go all the was across seat,  but will have to remove a small bracket under middle of seat, and the box will have to arch (?) up over the middle floor hump.  I have some old, ok don't laugh, crunch fatboy 10"drive series subs layin around and they are 6 1/2 inches total, from floor to top edge of woofer.  Maybe I can fit a 10 on each side, facing down,with the sub about 1 inch off floor?  or is that not enough distance.  I'll try to get measuremeant of total box area tommarrow.
Also,  thanks for all the help so far!
  • Who's Online   1 Member, 0 Anonymous, 2109 Guests (See full list)
